Put 2 elements in a Table
Make sure you have the whole column select before doing this.
Message 21 of 25
(928 Views)
Can I do this with property node "export data to excel" ?
how can I select the columns? :S
Message 22 of 25
(923 Views)
Like this but only takes the first row the first column :S
Message 23 of 25
(921 Views)
That's actually an Invoke Node and not a property node.
I'm talking about once you are in Excel, you select the column and use the menu choice to convert Text to Columns.
Message 24 of 25
(919 Views)
Ahhh when I'm in excel.... ups srry Jaj Ok I understand it's an easy way to do thanks. 🙂
Message 25 of 25
(913 Views)
