Pythonnode
Hello, I would like to use Pythonnode to transfer data from Labview to Python so that I can continue working with it in Python. So I would like to use Pythonnode only for one-way transfer, is this possible? Or is Pythonnode only meant to integrate a Python function into Labview? My problem is because it is a function I don't get any data displayed on Python that I can retrieve. Maybe I have to look for another possibility for the data transfer?
Thanks for the help
(850 Views)
Accepted by TheOne951
Python node allows you to call Python script from LabVIEW. It is like calling a DLL.
What you are trying to do is the reverse, calling VI from Python. Connect to a LabVIEW VI And Executable From Python
https://tmesystems.net/
(847 Views)
I agree with  ZYOng comments. You can use TCP or UDP to transfer data from LabVIEW to Python.
(781 Views)
The easiest solution is to have LV write a file that you read in Python.
Qestit Systems
Certified-LabVIEW-Developer
(736 Views)
