Query Interrupted VISA
Hello everybody,
I now there are lots of questions about the query interrupted in LabVIEW and I find anything, so I post here. I have a spectrum analyzer (R&S FSP) and I download the LabVIEW's drivers to use it. So I create a program to measure the noise and I had a problem of precision so I place on my program a VISA Write and VISA Read to have the result and it's work, but if I place an other block of the drivers, and after a VISA Write and a VISA Read, I have a problem of query interrupted, so if you have any idea about this, it will be great, there is a picture of this in the attachment,
sorry for my english,
Flo
(11,391 Views)
Accepted by Flod29
Assuming that the termination character is turned on, you might not be reading enough characters.  Set the bytes to read to something a lot larger (like 25) and let the termination character (usually an End Of Line character) stop the VISA Read instead of the number of bytes.
(11,374 Views)
Exactly Tim!
If you look close the VISA Read is throwing a warning.  "More Data may be available" I Bet!  And that silly R&S implementation of 488 throws a custom error when you try to speak to it when it wanted to say some more.
It is rather rude to talk over the device but, the instrument should have thicker skin and behave better.
Let the read end with the EOI/Term character and all will be better
(11,362 Views)
Thank you very much, It works perfectly, I put 25 for the number of octet,
Flo
(11,332 Views)
