Question about setting the filters on a NI-9253
I understand that the filter settings are at the module level for a 9253 - all channels on a module share the same settings.  I'm finding that if you have multiple 9253's in a task that concept applies to the task - all 9253 modules in the task have to share the same module settings.  Is this accurate??
Chronic
(265 Views)
You can try to set the subset channels using the Active Channels property before setting the filter setting. I have never tried that so I am sure if it will be supported but no harm to try.
https://tmesystems.net/
(216 Views)
