Quick question on converting number to string
I have a basic question to which I couldn't find a proper solution after searching the web. that I came across while developing a serial communication program. When I convert a number to string format, how do I preserve the leading zeros of the number? For example, the user enters 0025 in numerical control, I want to convert this to a string as "0025" but after conversion, it always returns as "25"
Thank you
Message 1 of 11
(3,520 Views)
Thank you
"Format Into String" is what you are looking for.
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(3,505 Views)
Hi ATX,
read the help for FormatIntoString, especially the paragraph on format codes.
Then you should know what "%04d" means…
Message 3 of 11
(3,478 Views)
Your Information is a bit ambiguous.
  • Is this a fixed format and you expect the user to input 4 digits?
  • What should happen if the user inputs 25 without leading zeroes?
  • What is the expected range of numbers?
Greets, Dave
Message 4 of 11
(3,474 Views)
Thank you
You can't "preserve the leading zeros" of a floating point number because there are none (the numbers are normalized and the MSB is 1).
However when converting a number to a string, you can choose a width and, if you use "Format Into String", you can choose to have leading zeros.
Message 5 of 11
(3,453 Views)
Accepted by topic author crossrulz
Note that you can use the format string of a numeric control:
Message 6 of 11
(3,448 Views)
If going that far, you should just use the Numeric Text.Text property.
Message 7 of 11
(3,442 Views)
Sure, if you're going to use the value in the control.
However you could have some other value wired in.
Message 8 of 11
(3,437 Views)
This is gold.
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(3,434 Views)
That's clever, never thought of that!
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 11
(3,431 Views)
