READING DATA FROM A SPREADSHEET
Hi everyone. I need trying to figure how to go about this situation. I created a VI which saves data in  a spreadsheet. The data has  25 rows and 3 columns.  Then I had read the data from the spreadsheet and display  graphically. The first column is  " Voltage", the second column is " Amps", and the third column is " Power".
I want to be able to display two graphs: One is" Voltage Vs Current" and the other is   "Voltage vs Power"
If any one can provided me with some guidance, I will really appreciate it.
Vincent
Message 1 of 10
(4,261 Views)
Hi Vincent,
read in the spreadsheet data as 2D array.
Then index the columns und bundle them to XY plots for a XY graph as needed…
Message 2 of 10
(4,252 Views)
Try this
Message 3 of 10
(4,231 Views)
Thanks GerdW,
                      I am going to give it a try and provide you with a feedback.
Message 4 of 10
(4,230 Views)
Hi Palanivel,
what are those FOR loops good for? You don't need them…
Message 5 of 10
(4,225 Views)
Hi Gerd You are rite... Thanks for reminding.
Message 6 of 10
(4,219 Views)
Hi Palanivel,
                   Thanks for the help. The only thing I could not find was the figures attached to the For Loops. Are they supposed to X-Y Graph symbols of something else?
Thanks.
Vince
Message 7 of 10
(4,204 Views)
Hi Vince,
you want to plot "x vs. y" data, so you should use XY graphs!
Message 8 of 10
(4,192 Views)
Accepted by SSHADOR
Huray!!, it worked. thanks to everyone who helped. Vince.
Message 9 of 10
(4,176 Views)
Accepted by SSHADOR
Thanks are given with kudos, and marking solutions.
Message 10 of 10
(4,150 Views)
