RGB CRT gun control through labview
Is there a way to directly control the low level graphic hardware? I am currently using Psychtoolbox in Matlab to display grating pattenrs on a CRT monitors and would like to know if there is a similar way to do that in labview.
THanks
(3,038 Views)
Hi AndyJosh,
I don't know exactly how the Pscyhtoolbox works, but generally LabVIEW can do anything that can be done in text based languages (including calls to the Windows API and/or your graphics driver), so what you are trying to do should be possible.
Also, you may also call your MATLAB® script directly using the MATLAB® script node found on the Mathematics»Scripts & Forumlas»Script Nodes palette.  Note that this requires you to also have MATLAB® installed on your computer.
Eric V
Applications Engineer
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,016 Views)
