 gminetti
			gminetti
			09-12-2023 03:28 AM
I tried the example files included in the driver package for RIGOL DSA815 downloaded from the web page at
I tried all 2018/2018/2020 versions. None of these worked with LabView_2019 (the only version not covered). From the screenshot you can see that the various sub.vi functions are missing/corrupted.
By launching the example files, the instrument goes in remote mode, but after a while the following error message appears.
Any ideas on how to fix it?
 dkfire
			dkfire
			09-12-2023 06:06 AM
You need to look at the commands that the driver send.
Look at Configure Sweep.
Does the "Format into String" format string use g or f as number format.
I had problems with the format string for all Rigol DP800 driver vi's.
09-12-2023 08:31 AM
Thanks for your support, the Configure sweep code is:
 dkfire
			dkfire
			09-12-2023 08:38 AM
Try to change %g to %f
 Frozen
			Frozen
			09-12-2023 10:06 AM
There are sooo many things wrong with that driver. I have complained before about this (although, I cannot find it atm)
Here is my "correction" to the sweep configure, but I did not leave myself any notes why I did it.
**WARNING** "\Public\Data\Low Level\Wait for Acquisition Complete.vi" is just plain WRONG! Luckily, it does not break your code. And no, I did not fix it either.
Good luck!
