RPM-Torque and throttle position - 2 Inputs 1 output
Hi All,
I'm trying to model a Formula Student drivetrain in LabVIEW, and to get an initial engine torque depending on the RPM and Throttle position, I've ran a simulation on another piece of software to get some generic values. I've attached an Excel file with these values on it.
What I would like to do is set up my LabVIEW model so I can input a value for the specified RPM and Throttle position so it will give me the corresponding torque, however, I have no idea how to do this. Any help would be massively appreciated.
Many thanks,
Dan
(2,973 Views)
Accepted by ChangoMutney
Look at the interpolation and extrapolation palette (inside the mathematics palette).  There are vi's for 1D and 2D arrays.
(2,937 Views)
The array palette also has a threshold 1D array and interpolate 1D array that can be used.  I am guessing it would be a more "manual" way to get your data.
(2,884 Views)
