RS-232 DATA SEND TO Iinstrument
Converting a string to a byte array and back to a string does nothing.
Message 11 of 14
(300 Views)
Hi
is the string type entered in the visa write buffer considered as binary or hexadecimal please?
I'm learning labview and sorry for my questions if they are not consistent
Message 12 of 14
(292 Views)
Accepted by Fredo123Danzel
A string is a string is a string, and this has nothing to do with LabVIEW. The look is purely cosmetic and does not change the underlying data.
If you want to enter the data in hex, set the display to hex.
Message 13 of 14
(282 Views)
The module has several operating speeds but it does not accept 9600. So I set my via visa to write at 115200 speed, configured the radex of the via containing my data in hexadecimal reading and the problem is solved. Thanks for your help!
Message 14 of 14
(237 Views)
