RS232 Communication with Mastech MS2203
I'm trying to visualize the data from a Mastech MS2203  in LabVIEW using RS232 serial port.
I have the initial config settings (baud rate, parity etc...) that I could get using PORTMON, but I'm still no sure what to do next.
I couldn't find the serial protocol for this device, but I have their software that does exactly what I'm trying to do.
I have attached the software display and the PORTMON data that I got while I was running the program.
Does anyone have any ideas on what I could do next?
Thank you!
Message 1 of 8
(6,920 Views)
Need to get the serial protocol specification from the vendor of the Mastech MS2203 to know how to parse the hex data.
620.00000310DigitPower.exeIRP_MJ_READSerial0SUCCESSLength 22: 05 05 10 04 E0 FB 60 60 05 44 28 EB ED FD CF ED 60 00 00 00 1F
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 2 of 8
(6,892 Views)
Accepted by kennycaldas
You will find your answer here: http://www.multimeterwarehouse.com/MS2203Protocol.pdf
Matthew Fitzsimons
Message 3 of 8
(6,890 Views)
That's not exactly readable.
Message 4 of 8
(6,877 Views)
Thank you Matthew!
With that file and a little help from Google Translate I could read the voltage in LabVIEW.
Message 5 of 8
(6,841 Views)
Glad I was able to help out.  Good luck!
Matthew Fitzsimons
Message 6 of 8
(6,834 Views)
dear,
i also facing same problem.can you share your labview file for this instrument to me.
my email id is- ashutoshpatelm@gmail.com
Message 7 of 8
(6,403 Views)
Dear  patel1508,
I don't have the code for this multimeter anymore, sorry.
But I remeber I used the code provided in this post as a starting point for my application:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Cheapest-RS232-Serial-DMM-with-LabVIEW-instru...
You'll have to change some parameters to work with the mastech device, but you'll be able to have a pretty good idea on how to do it
hope that helps.
Kenny
Message 8 of 8
(6,351 Views)
