RS232 and Graph
Hello Crossrulz !
Thanks for your reply.
You are right, I don't use the 'writing part' in Labview. It makes more sense to delete it.
I have followed your diagram and it works perfectly ! Thanks !
The history has been well cleared when I start recording.
[Quote] And don't use the Abort.[/QUOTE]
Maybe a silly question. Is it a bad habit to stop by using the Abort ?
Alright for the 'Run' advice, I will keep that in mind.
Last question :
How does a chart display value according to the time ?
I mean if I send datas every second, does it display every second ?
If I send datas every minute, does it display every minute ?
Can I control that ?
Thanks again
Message 11 of 21
(1,677 Views)
The Abort button should only be used as a last resort.  Think of it as an E-stop.  You are just shutting everything off instead of doing a proper shutdown.  You need to let your VIs stop on their own to make sure everything is being properly cleaned up.  This goes along with closing your serial port when you are done.
The chart will just put up data when it gets it.  By default, the chart has an X axis of samples.  You could build your data into a waveform and then it will be able to chart based on time.  But that might be more trouble than its worth for you.
Message 12 of 21
(1,670 Views)
Alright, thanks for the advices !
I would like to thank you once again Lynn and Crossrulz, I appreciated a lot your help and your explanation.
I will tag this topic as 'resolved' with the last screenshot (even though, all anwers help me, of course).
Have a nice day !
Message 13 of 21
(1,658 Views)
hi you
i am  made my project to gather data from sesor
but it isnt running
please help me
mail trinhminhtuan.autmobile@gmail.com
Message 14 of 21
(1,607 Views)
How can someone help if you don't provide any information about your problem.
Read How To Ask Questions The Smart Way
Message 15 of 21
(1,604 Views)
It's also not so smart to put your email in a public forum, unless you like getting spam.
Message 16 of 21
(1,600 Views)
hi you
sorry
here is error and my project
Message 17 of 21
(1,573 Views)
Message 18 of 21
(1,571 Views)
i wanna to gather data from lm35 sensor (really, i replace my sensor by lm35) and my sesor is pressure sesor
thank you for assistance, if can, please set up time for me ( i caculate 10ms/ timer period)
Message 19 of 21
(1,568 Views)
You still have not posted any code. The project file does not include the actual VI.
Message 20 of 21
(1,569 Views)
