RS485
Hello again,
i checked Manual and for me it´s not clear.
I also prepared a reduced PDF document with RS485 instructions from this device.
Best regards
Message 11 of 14
(620 Views)
Hi Dicker,
according to your PDF the "payload" data seems to be readable ASCII.
But you missed to attach the description of the BCC calculation…
Message 12 of 14
(617 Views)
Hi Gerd,
no i didn´t Forget. It is not included. I must ask manufacturer.
"according to your PDF the "payload" data seems to be readable ASCII."
what do you mean?
Greets
Message 13 of 14
(611 Views)
Hi Dicker,
what do you mean?
I mean you can use string constants set to "n" display mode for the parts of the message defined as ASCII…
("Payload" typically describes the part of the message that hold the actual/relevant data. The other parts are things like start of message indication, IDs, number of bytes indication, EOT byte(s), BCC byte(s), …
Message 14 of 14
(604 Views)
