Read/Write From/To Binary/Text File
Thanks Thoric
Message 11 of 17
(956 Views)
@Mark_Yedinak wrote:
I don't think the formula node will accomplish what the OP wanted. In order to input equations/formulas from an external source at runtime you will need to implement a parser in your code that will evaluate the formula and execute it. Essentially you will be creating a calculator in your code. It is certianly doable but depending on how complex your formulas are it coude be a significant amount of work.
Oh, I thought he meant he already had a bunch of LabVIEW code and he just wanted to condense it into something manageable.
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(944 Views)
Yes i do already have all my subvi created. But may need to be changed in the future so i figure this way would make it easier for updates to the code.
Message 13 of 17
(936 Views)
As suggested earlier you could use a plugin approach and call the subVIs dynamically. This would require you to develop the LabVIEW code to support the new formulas. If you need your users to be able to add formulas the parser route may be your best option.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 14 of 17
(933 Views)
Thanks again to all for the input!
Message 15 of 17
(930 Views)
If you opt to go the parser route, there is an example of one in the CLD-R sample exam A, #22.
https://lumen.ni.com/nicif/us/custedcldrexamprep/content.xhtml
Adam
Message 16 of 17
(923 Views)
Thanks Adam
Message 17 of 17
(918 Views)
