Read image and convert to unsigned 8 bit 2D array(but show size 0 X 0 )
Hello, I am a rookie to the labview.
        What I want is to read file and do the edge detection.
        I have using the example: edge detection with 2d convolution, and try to modify it.
        I have using about three different methods but all of them jump to the error: not an image.
        1.using imaq to read file and using the imaq edge detection.
        2.using imaq to read file and using the built-in 2d convolution vi.
        (using imaq cast image amd imaq image to array to convert to unsigned 8 bit grey image)
        3.using read jpeq to read file and using the built-in 2d convolution vi.
        I have fight with it and try to fix it but in vain. And I don't know the reason what cause the error.
        How do I fix all of the version?
Thanks for you reading my question.
        The attachment is the vi I have tried and the test image.
(3,942 Views)
Accepted by XXZERO12
@XXZERO12 wrote:
[...]  3.using read jpeq to read file and using the built-in 2d convolution vi.
hi,
1# your input picture has a depth of 24 bits, so you have to wire the 24-bit output of "unflatten pixmap.vi";
if you don't wire the correct output, the resulting image will be empty.
2# you need only 8 bits for the "convolution.vi", so you have to convert from [0;1;2;...;(2^24)-1] to [0;1;2;...; (2^8)-1]  for example like this:
Alex
(3,875 Views)
Thx, it helps me a lot and give me the reason what I make mistakes so that I won't make mistakes again.
I really appreciate your help!Smiley Happy
(3,861 Views)
alternatively, you could use "scale by power of two" to convert from 24 to 8 bits:
Alex
(3,843 Views)
