Read source distribution Version
Hi!
I plugged in my Build a source distribution
I plugged in the interface version properties. I would like to read in front of the main VI
how can I do?
At the moment I can read the version of the entire build use as in the attached
Thank you!!
(3,992 Views)
If you want to get VI revision number,
It is Property node, right click to Select class -> Vi Server -> VI -> VI. Then property History -> Revision number
(3,980 Views)
thanks but not what you need.
I want to be able to view the source  distribution version and not the individual VI
in practice the figures included in the properties of source  distribution
(3,978 Views)
Try this ...
(3,965 Views)
thanks for your time but it still does not work: returns the build version and not the source distribution
(3,940 Views)
