Read text file problem format and precision
Dear all,
I have  a problem in reading the text. I tried opening the file with the "read spreadsheet file. vi". I think there is some problem in the format and precision.But i cant plot the graphs properly. I the text file that i have attached the first column is the X-axis and i like to plot the other 6 columns to that.
Please help in opening this file so that i can view all the graphs.
Thank you,
Bala
(2,701 Views)
Accepted by bala1234
The file looks perfectly suited for "read spreadsheet file". How did you configure this VI?
Make sure you read DBL precision data and use TAB as separator.
Probably you need transposed data for the way you try to plot it?
Can you post your VI?
EDIT: or probably the zeroes at the end of the file cause problems in your plot code.
(2,698 Views)
Thank you very much i fixed the problem.
(2,676 Views)
