Read value from excel
I'm using LabVIEW 2015 without Report Generation Toolkit.
And I wanna read value from excel.
I got  a useful VI for that.
But It seems it had a limit on the number of columns.
I wanna read about 40 columns but it read only 26 columns.
Can you show me what property I should change?
(2,607 Views)
Accepted by topic author kimtae
Hi Kim,
Because of the way the cell "range" is created…
Compare the column labels in Excel with the column labels/ranges created in that VI!
Suggestion: You need to refine the way how those ranges are created…
(2,593 Views)
Hello, GerdW.
Thank you for write a comment about this.
I appreciate about it.
Where I should compare is these red circles?
I try changing the 'column' constant to 100 but it didn't work.
The number of columns was limited to 26.
Or did you mean something else?
(2,589 Views)
There are 26 letters in the Latin alphabet. After column "Z" Excel expects column "AA".
The range is calculated here:
The attached VI is from an old library which has served me well and should work for you.
Note that the rows and columns start at 1 not 0.
(2,578 Views)
Ah That 26 was the number of Alphabet!!!!!
Thank you very much.
I will try to change my coding, referring your VI file.
Thank you very much and God bless you and have a good day and
you will make many money.
(2,561 Views)
