Reading AREA File with LabVIEW 2009
Hi all,
I have a device connected to my PC which stores the data in an ASCII file type "file.area".
When I open this file with Excel, I can read the data. Butwhen I open it with a text editor (such notpad++), I see Chineese lines... Same thing when I open the file with LabView.
I have attached an example of this type of file (compressed).
So, can I export (convert) this file to an .XLS file using labview in order to exploit it later ?
Is it possible to eploit directly this file with LabView?
PS: It is NOT possible to create .TXT or .XLS file directly by the software of this device.
Thank you in advance,
(2,889 Views)
Accepted by HoussamAz
Just rename it to .xls!
Use excel examples like this one: https://decibel.ni.com/content/docs/DOC-16042
If you do not have report generation tool kit it still is possible to read it using ActiveX
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,880 Views)
Cool, it works !
Thank you !
(2,876 Views)
