Reading Back the Value of a Digital Output
Greetings,
I am trying to display the state of a boolean written to a DO. I tried to use the VI provided at the following link by NI as a starting point (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGDISA2&l=en-US). The readback in the VI provided seems to cycle through possible boolean states rather than reading what is written. I am using a simulated DAQ device (a simulated 9375) for the DO. Is this just a problem with simulated devices or does the VI provided by NI not work in the way it is stated?
Eron
(1,039 Views)
Accepted by eronjacobson
That is just the nature of using a simulated device: all reads just cycle through the possible values (counting pattern).
(1,031 Views)
I agree that we should have the ability to define the behavior of a simulated instrument. See also my comment here.
(994 Views)
