Reading a 2D array from a binary file causes memory error
What is weird about the naming convention.  It is a standard one to avoid blank spaces.  startWithLowerCase andUseUpperCaseInsteadOfSpace
or are you referring to the actual name "whatTheHeck"?  that was my reaction...    It's a mock VI to test out a solution.  It gets deleted at ythe end of the day.
R
Didnt mean to offend you. I just mentioned cause i do the same and in addition retain the same names and there are times where i used search for the vis and think of the mood in which i was while programming it.
Message 11 of 24
(1,621 Views)
Guys...!!! Please...  enough discussions about 5 stars..
There's no need to discuss it over so many threads.  And no need to hijack threads to discuss stars..
Just help put others.  Learn and share your knowledge.  It's not about stars.
------ SIGH ------
Message 12 of 24
(1,620 Views)
You reap what you sow, Ray. You guys started the star obsession and now you've got some followers who will outdo you. For that matter, you also started the yapping tradition, so... Smiley Very Happy
P.S. Any reason you're posting all those images to the icons thread? There are certainly reasons NOT to do it.
___________________
Try to take over the world!
Message 13 of 24
(1,595 Views)
Yes..  That's where I copy the icons from.  I had promissed Ben to give him the latest collection almost a year ago.  Didn't think it would offen you. 😮
And I agree that it was foolish of me to discuss the star issue back then.. 😞
Oh well.... live & learn...
Message 14 of 24
(1,585 Views)
I was refering to the code images (still not created with the CCT ) , not the emoticons.
Message Edited by tst on 07-30-2008 09:34 PM
___________________
Message 15 of 24
(1,570 Views)
I don't think Tst was talking about the smileys, but talking about the images attached to post #1.  As well at the images in posts #304 thru #307 of the icons thread.
Message 16 of 24
(1,573 Views)
Oops..  sorry tst.
Yes... I know... I need to install that piece of SW and start using it (and yes, I recall saying that before..)
I looked at some posts from Ben where he posted the images elsewhere and simply placed the shortcut into the actual post.  I adopted that when having images and code posted in the same reply.  Plus it made writing the reply easier by having the image there.  It is annoying to post the image first, then the reply...  So I may not adopt that method any longer..
I did download the program and will give it a try 😉  Just look at how long it took me to view the threads in the same order LOL!  But I was much faster at adopting the MACROs.
Sorry about that.
R
Message 17 of 24
(1,567 Views)
Here are some of the issues with it:
  1. It fills up the icons thread with posts, which makes it harder to search for a certain post (e.g. if I'm looking for a new icon). Ben actually used a different thread for that purpose.
  2. It also appears as another new post, which means I "have" to go in and have a look.
  3. It's not in the same thread. If NI ever changes the forum structure (which isn't that unlikely), the link will be broken and someone else running across it will not be able to use it.
P.S. We're not forcing anyone to use the CCT. It's your choice. Smiley Tongue
Hmm, maybe I should get Jeffery to have it as a requirement for the champions...
___________________
Message 18 of 24
(1,550 Views)
LOL!!
I do want to try the CCT.  Although I will probably edit the image to take less screen real-estate.. 🙂
Message 19 of 24
(1,542 Views)
If you're refering to the FP, it has three capture modes: selected, visible and all. You're probably using visible. Changing to one of the others should help.
___________________
Message 20 of 24
(1,527 Views)
