11-15-2004 03:07 PM
11-16-2004 05:25 PM
11-17-2004 01:11 PM
11-17-2004 03:23 PM
11-17-2004
04:26 PM
- last edited on
07-22-2026
10:05 AM
by
Content Cleaner
Hi Kevin,
Great to get your help once again on the discussion board!
I was thinking about using the Change Detection feature as you mentioned, but apparently this feature isn't supported by NI. Check out this discussion [broken link removed].
If I can't use change detection, I had another idea, which was to build a little digital hardware that would merge the three event signals together onto 1 line, i.e. make a square pulse every time one of the events happens, then use this 1 line as the sample clock for the counters *and* 3 digital inputs, which would be connected to the lines that signal the e
vent.
My other idea was to use a PXI-6602 or PXI-6608 counter card and just dedicate a pair of (synchronized) counters to each event type. Do you have any experience witht those timer/counter cards? Do you know if you can cascade 2 counters together?
Thanks again!
Cas
11-18-2004 10:51 AM
