Reading data in multiple case statements
I have tried this code but still have the case that the input to the case statement looking for 0x6100 is always zero.  Does it need some conversion required?
Message 11 of 16
(1,187 Views)
I suspect the constant you used for the Type Cast or Unflatten From String is an I32 (the default representation for a numeric) when it should be an U16.  If you upload your VI, we can check that and other things that are easy to miss.
Message 12 of 16
(1,175 Views)
You can use \-codes in the case selector:
Message 13 of 16
(1,152 Views)
Assuming we know it is a U16, it is better here to cast the string value to a number and then right-click on the case structure and choose Radix->Hex.  At least it makes it a lot easier to read.
Message 14 of 16
(1,128 Views)
Oh yes. My post wasn't a recommendation, just a bit of trivia. 🙂
Message 15 of 16
(1,113 Views)
That is interesting. I never knew that.
Thanks for the tip 🙂
Former Certified LabVIEW Developer (CLD)
Message 16 of 16
(1,100 Views)
