Reading data saved on previous version of Labview
I've recently bit the bullet and upgraded to Labview 8.0 after using Labview 7.0 for a good few years now. I'm currently experiencing problems accessing data saved on the previous version of Labview which I've been working on until the upgrade.
An example is the waveform files saved on Labview 7.0 which I'm trying to read using Labview 8.0. A dialog box appears when I try to use Labview 8.0 to read the waveforms advising me to convert the files to the new version of Labview which I've duly agreed to. However, it appears that the conversion process has managed to corrupt the waveform files as I am unable to access it on either Labview 8.0 or 7.0.
I'm including a couple of files to highlight my point, one saved on Labview 7.0 and the other converted to Labview 8.0 by the programme.
Cheers.
(2,556 Views)
Hi
Have a look at this thread: http://forums.ni.com/ni/board/message?board.id=170&message.id=163651
There you'll find a workaround regarding the message.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,553 Views)
Thanks.
(2,542 Views)
