raised frame error
Wonder if anyone encountered this error when using Decorations/Raised frame
Once I put my buttons in, they simply would not work! Although sometimes it works...
I'm using version 7.1
Message Edited by kingkong on 05-11-2006 01:52 AM
Message 1 of 8
(4,386 Views)
Hi kingkong,
It will be great if you would post your VI here.
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 8
(4,379 Views)
I have already solved the problem by redrawing a raised frame over the buttons, hence I lost that error version.
The thing I noticed(during the error) was when my mouse cursor was over the buttons, there were no highlighted framepoints of the buttons.
Instead only framepoints of the raised frame was seen. Subsequently when I proceeded to remove the raised frame, immediately my buttons work.
Queer...
Message Edited by kingkong on 05-11-2006 03:50 AM
Message 3 of 8
(4,374 Views)
Then it must have been due to the different layers - the button (although visible) must have been behind the frame. You just could have moved the frame to the back - this should have solved your problem.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 4 of 8
(4,367 Views)
I see... Maybe! Thanx pals!
Message 5 of 8
(4,363 Views)
Hello kingkong,
did you draw the frames after making all the buttons? Then the decoration is in front of the buttons and thus disabling access to them.
Just use the Forward/Back button on the front panel menu line to put the decoration "to back"!
Message 6 of 8
(4,362 Views)
Hi, I did a simple experiment...
The layer position of the frame (Raised/Flat/Recessed) is not affecting the controls placed in it.
Hope I am right 🙂
Cheers!
ian
Ian F
依恩与LabVIEW
Message 7 of 8
(4,359 Views)
I just tried this in LV8.0. I place a button on the front panel and then I placed a raised frame "over" the button (though the button was still visible). There were no problems to push the button. Maybe there was some kind of "bug-fix" on that topic.
Using LV8.0
Message 8 of 8
(4,358 Views)
