Reading from CO2 sensor connected to the PC
Hi Raven!
Ah thanks buddy! Putting a space infront of my Z fixed the error!
Actually I would just like to do what is most reasonable. What do you suggest doing instead? 🙂
Did I not use the Scan From String on the data that came out of the VISA read?
Greetings
DP
Message 21 of 63
(1,876 Views)
No.  You used scan from string on the string where you keep concatenating all of the new VISA read data at the end.
I think adding the space in your search string (if that is where you are talking about adding a space) is a mistake.  The other lines that were the newer data you should've been analyzing did not seem to have that space.
You need to figure out why that space was there.  Perhaps it was other problems in your code.  If it is there sometimes and not others, consider using a "Trim Whitespace" function to clean it up before you feed it through the Scan from String.
Message 22 of 63
(1,851 Views)
Hi Raven
Sorry I haven't responded before.
Could you take a look at this VI and tell me how to improve it. Please do not rip your eyes out because I know it probably looks horrible.I know that using write to measurement file is wrong and there probably is alot of ways to do it better but this way I have been able to get the VI to do what I want.
I added the VISA serial write and read at the bottom of the VI and everytime it starts reading everything else in the VI just slows down extremely. What is the cause of this?
Greetings
DP
Message 23 of 63
(1,819 Views)
Hi DP,
which VI?
(When you attach your VI could you please provide it with LV2014 or older?)
Edit: You attached the VI while I was writing this message…
Message 24 of 63
(1,816 Views)
Hi Gerd
Whenever I try to save as a previous version I just get a folder with the same exact version? I have been trying several times....
Greetings
DP
Message 25 of 63
(1,810 Views)
Can you open this one?
Greetings
DP
Message 26 of 63
(1,803 Views)
Accepted by DP123
Hi DP,
It gets slow because you programmed it this way! THINK DATAFLOW!
Put the serial communication into a parallel independent loop…
Message 27 of 63
(1,795 Views)
Hi Gerd
Thanks that worked :)!
I will try keep working on my original problem which was to get the chart to work properly and write the data to a file. It was also mentioned if I wanted to build up one long string of all the responses by Raven. Was he thinking that I should remove the shift register?
Greetings
DP
Message 28 of 63
(1,789 Views)
Hi everyone
I can not make the chart work. I keep getting an error no matter what I try. Any suggestions?
Greetings
DP
Message 29 of 63
(1,747 Views)
Hi DP,
Which chart?
What kind of error do you get? Error numbers? Error messages? BSOD?
Any suggestions?
Attach your current state of the VI. Explain where exactly you have problems with!
Message 30 of 63
(1,745 Views)
