Recording data from graphs
Thanks so much
Sorry am not from france.. from GHANA currently in japan working on a satellite projeect called  Horyu-4
Using labview i need to build a downlink software and a main GUI to monitor uhf/vhf ground station and S-band ground station
I will be happy if you have time to guide me, your examples are helping me a lot
I appreciate
Message 11 of 12
(958 Views)
Hello Mon39por,
I am also new in LabVIEW, I have been using it for only 6 months and I do mainly spectral analysis, which is also new for me.
So, I am not sure I could help you very much, but if you encounter a problem, post it in the forum and explain your problem accurately, just  as I did many times.
There are a lot of very very competent and helpful people here
Little by little, you will build your solution. Good luck with your project.
Alain.
Message 12 of 12
(943 Views)
