Recordset Data
How can i show myrecordset datas in a table without "value ->" or in a array of clusters without "value->"
Thank you.
(6,260 Views)
Since you have provided zero information on the actual record set, how you are reading it, etc., it is just impossible to say what you need to do.
(6,246 Views)
That is how a variant looks.  How would you like to display the data?  Where is this data coming from?
The short answer is that you will want to format all of the data into strings and then use a Table.  But how to convert all of your data to a string could be interesting, depending on how your application is put together.
(6,240 Views)
Use database varient to data. After conversion -> will not appear. See image for reference
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(6,202 Views)
I added my db table and my block diagram.
Ranjeet I did but i cant set type my db dable have numeric + string + date but when i try create a empty cluster like my columns i see type error (broken wire) in attachment 1.PNG
(6,174 Views)
Accepted by keremgeliz
Now i fix my problem. Thank you for your help.
(6,167 Views)
