07-07-2008 05:57 AM
Below is the help and calculation available in the “Timing and Transition Measurements” for deriving Duty cycle
Pulse duration—Calculates the time difference in seconds between the first two middle references level crossings. Pulse duration also is known as pulse width.
Period—Calculates the time in seconds between adjacent middle reference level crossings in the same direction. The reciprocal of this value is the signal frequency.
Duty cycle—Calculates the Pulse duration as a fraction of the Period.
Please clarify the following points.
This will help us to configure the voltage level to handle our exception for curve edges with high frequency in our application.
Thanks & Regards
07-07-2008 05:58 AM
07-08-2008 11:05 AM
Hi Anitha,
Are you using the Timing and Transition Express VI? This express VI, because the code is written for you, can be relatively limited in the provided functionality. I do not believe that there is a way to set the reference levels. If you are interested in doing so, I would look at the example program entitled Pulse and Transition Measurements. This example VI generates a signal set up by the user in the first case structure and then analyzes the signal for a number of settings in the middle case structure. On the block diagram, if you look at the Pulse Meas. case of the middle case structure, you will see it contains the Pulse Measurements.vi, which outputs period, pulse duration, and duty cycle based on the inputs of the signal and a cluster of numeric reference level controls. This function will, I believe, give you the fine control you need.
Hope this helps,
Mallori M.
