Relative time on waveform chart
Hi kdm,
you ask why?
Because you are using a chart despite of being told to use a graph instead!
Because you are resistant to follow people's suggestions!?
Do you mind to attach your VI with some example data (or a loop generating example data)? (LV2011 preferred)
Message 11 of 19
(2,171 Views)
Hi GerdW,
Here is the VI
Message 12 of 19
(2,153 Views)
Hi kdm,
which chart are you talking about?
Create a graph instead. Much easier!
What's the point of all those sequence frames? What's the point of all those local variables?
Message 13 of 19
(2,143 Views)
Hi all,
I have set conditions to start graph at 6am. I want it to stop graphing at 18:00. Anyone has any ideas?
I have attached my VI.
@Gerd  Thanks.
 I was talking about the power chart.
Message 14 of 19
(2,124 Views)
Hi kdm,
when you want to graph between 0600 and 1800 you should check the hour of the current time. Right now you only check minute and second…
And of course you have to change the array build too. Right now you will graph all data as all data is collected…
Message 15 of 19
(2,118 Views)
Hi Gerd,
Thanks a lot! Smiley Happy
Message 16 of 19
(2,090 Views)
@Gerd,
As we need to use build array for graphs, won't it increase the memory usage? My labview software crashes when I use build arrays (reason: high memory usage).
Also I am more familiar with charts and prefer to use charts.
Problem now: The chart points (on the attached vi) has reached more than 15:00 (time), when the current time is still 14:13. I have set the multiplier as 0.5 (as loop time is 0.5). What could be the reason?
Message 17 of 19
(2,088 Views)
Hi kdm,
Yes, you need to limit the memory usgae. The same as you do by setting the history size of charts…
Your continued changing of X axis offsets?
Message 18 of 19
(2,079 Views)
Hi Gerd,
I have set the "offset code" outside the while loop and again set "offset" at a clear graphs loop (which is inside the while loop.. (It is not shown in the above vi).
This looks complicated and I think it will use more memory. Is there a better solution?
Message 19 of 19
(2,074 Views)
