RemotePanel.ConnToServers property not returning results
Hi!
I'm trying to detect remote panel connections to my labview app.  I have created the following snipped of code:
When I run this and then connect remotly with this other computer sitting next to me, the array remains blank.
I'm using LabVIEW 2009.  Any input greatly appreciated.
(2,918 Views)
Can you tell me more about your set up. Are you hostinging any remote panels on that computer? Are you using the embed, snapshot or monitor option? What Version Of LabVIEW are you using?
(2,892 Views)
Accepted by hecmar.arreola
Turns out that particular property of the App reference will not get you remote panel connections.  Not sure what that particular property is used for.
The remote panel connections list is accessable through an Invoke node of a VI reference.  If you open a reference to the current VI, you can get a list of remote panel connections and make decisions based on this list:
-Nic
(2,856 Views)
