Remove 2nd cluster from another cluster
Attached is my code that gives the error.
Thanks.
Message 11 of 13
(769 Views)
There error is expected while cycling through the elements that are not an array. The loop should stop once it was OK.
here is a mod of your code showing how to find the array "by name".
Have fun,
Ben
After thought: I have been assuming that you know about "Unbundle by Name" and that does not meet your needs. If not try it.
Message Edited by Ben on 09-02-2009 01:16 PM
Message 12 of 13
(760 Views)
Sorry, I was looking at the index #0 of the value array, not the fifth like the data array is inside the cluster.  That was my mistake.
Thanks for all the help Ben.  I will keep working on this to pass the appended cluster to another vi without the data array.
Message 13 of 13
(747 Views)
