Remove string from txt file
@apok wrote:
Why are you using the Delete From Array?  The Array Subset is a lot more eficient.  And then you are only using the last output.
Message 11 of 20
(1,830 Views)
@crossrulz wrote:
is a lot more eficient....
how do you mean? please show me...
Message 12 of 20
(1,820 Views)
There is a lot involved with the Delete From Array.  The Array Subset just copies out the portion of the array you want.  The Delete From Array also has to compact the other array, creating more data copies.
Message 13 of 20
(1,814 Views)
You can use regular expressions to extract the data you want.
Ben64
Message 14 of 20
(1,812 Views)
A string parsing thread can't be complete until somebody mentions regular expressions.  I'm surprised it took this long...
Message 15 of 20
(1,809 Views)
I'm also surprised !!
The lookahead is useless in this case. The following regex will do.
(\d+:\d+:\d+)(.*?) Inspection Finished
Ben64
Message 16 of 20
(1,800 Views)
Ben64
Could you post the VI the drag and drop only gives me the forum link for some reason
I have not lost my mind, it's backed up on a disk somewhere
Message 17 of 20
(1,799 Views)
Accepted by topic author PauldePaor
see attached
Ben64
Message 18 of 20
(1,795 Views)
Dragging straight from a web browser just doesn't work for who-knows-what reason.  But you can drag the snippet to your desktop to save the image file there and then drag from your desktop to a VI and it works.
Message 19 of 20
(1,789 Views)
hmmm....in my example, the assumed data file was to change size and will handle that. How do you handle it when the data  grows?Does the efficiency have to do with bench mark time here?
EDIT: i didnt see your comment on data copies....my bad Smiley Sad
Message 20 of 20
(1,782 Views)
