Remove student edition watermark from a professional edition of labview
I agree that this looks like a licensing issue. I would suggest you contact NI Tech Support directly. Since you have legal versions of LabVIEW they will be happy to help.
Message 11 of 15
(981 Views)
I will try that.  Thank you.  If that resolves the issue I will post the solution in case others have this issue.
Message 12 of 15
(978 Views)
What I meant to say is that Parallels appears to be better on a mac that VMware. If you use a PC VMware is better. You can get VMware player free of charge for non commercial use. VMware Workstation is about $198.00 - much cheaper than a second PC.
But that solution is probably overkill and your problem is likely a licencing issue.
LabVIEW 2012
Message 13 of 15
(969 Views)
Accepted by Dashiva
I do appreciate all the input and I apologize for any confusion on the matter.  I called NI in regard to this issue, they suggested a repair on the professional edition.  So far this has worked for me, the watermark is gone.  He said the my uninstall could have failed to remove everything.
The only downside to this was that it removed all of my serial numbers from my license manager and spalsh screen (when it loads).  If any problems persist I will try to bring it up, but as long as labview works and is running (w/o watermarks) I'm happy (and so was the applications engineer).
Thanks again for everyone's input.
P.S.  For the virtual machine, that was a great idea, but yeah I didn't want to spend more money on an already brand new computer that has yet to run labview :).
Message 14 of 15
(963 Views)
VirtualBox is free.
Message 15 of 15
(941 Views)
