Replace File Name of Path
EDIT:
I am trying to build a string array into a path, however it ends up not being formatted correctly.  Perhaps this is a "scan code" issue with the backslashes?
Is there a better/correct way to do this?  I want to just change the file name of an already existing path.
For example:
c:\Desktop\Folder\File1.csv
becomes
c:\Desktop\Folder\FileName.csv
My "Spreadsheet String" is just a Path to String of an existing file path in the same destination folder.
I break the old path (in string form) into an array seperated by the slash.  Then I replace the last array element (the file name).  Then I make it an array again and convert it to a path.  Although it looks correct, LabVIEW throws an error with this path saying it does not exist.
If someone helped you out, please select their post as the solution and/or give them Kudos!
(4,075 Views)
Accepted by MrHappyAsthma
Is this what you're looking to do ?
appended path = c;\desktop\folder\filename.csv
(4,043 Views)
That looks about right.  However I am unfamiliar with that first function.  Could you please link me to the help document for it and maybe explain what it does?
(4,040 Views)
Both functions are in the File I/O palette. Strip Path & Build Path.
You can turn your context help on with Ctrl + H to see the details Smiley Wink
(4,036 Views)
Ah, yes!  Thank you!  The Strip File Path function did exactly what I needed in a very robust way.  I cannot believe I had never come across that function before.  It would have saved me much struggling 😛
(4,031 Views)
Yes there are some little gems hidden in them there palettes !
Thanks for the kudos ... Smiley Happy
(4,022 Views)
