Report generation toolkit
I'm trying to insert and format two graphs in Excel using the report generation toolkit.
The first graph is well inserted and formatted, the second one is well inserted but wrong formatted in width and height. A sample code is attached.
Thanks.
(3,102 Views)
Take a look at the attached code and see if that won't work for you.
(3,102 Views)
It worked! Thanks a lot!
(3,102 Views)
