RichTextBox
Hello.
The question is how to get .NET Refnum of a certain *.rtf file in order to put it's contents into RichTextBox container.
Thanks.
(6,111 Views)
Hope this helps
LabVIEW includes the following refnum controls located on the Refnum palette:
.NET Refnum—Use this refnum to launch the Select .NET Constructor dialog box and select an assembly in the Global Assembly Cache (GAC) or navigate to a private assembly.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(6,101 Views)
Accepted by TerraNova
You should really stick to your original post so people know what you are trying to do.
ABCPrograms wrote:.
Hope this helps
- Bjorn -
That's not how you would do it. You'd insert a RichTextBox into a .NET container on the front panel.
@TerraNova wrote:
Hello.
Thanks.
Did you try a search? Examples have been posted on how to use a RichTextBox in LabVIEW. All you need to do is this:
(6,091 Views)
Done with that.
Thanks.
(6,086 Views)
