12-14-2007 01:52 AM
12-14-2007 03:00 AM
craigdobis wrote:
Is there a way in Run-Time Menus to change the font or font size of the menus? This is in LV8.5 that we are working on, W-XP.
12-14-2007 03:04 AM
Sorry, not finished yet, due to posting problem... ![]()
I think you were talking about changing the Font & Font Size of the RTM, not the font of LV on the whole, right?
If I m wrong, please correct me.
12-14-2007 07:21 AM
12-14-2007 07:34 AM
Yes, you are correct. I meant to change the RTM font and font size. However, if any of you have created your own menu bar to replace the RTM, I would be very interested in seeing that. I am sure with all the extra creative minds on this forum, someone must have created their very own, super-fantastic menu system.
How about a "Flash" menu in an Active X container? Hhmmmmm....
I will have to think about that one.
Thanks to all of you! MERRY CHRISTMAS !!
12-14-2007 07:42 AM
I think either National Instruments used to ship an example with fly-out menus before they offered the tree control, or I saw something like this in LabVIEW Technical Resource many years back. I am sure someone still has that example somewhere.
And speaking of the tree control - maybe you can customize this and use as a menu?....Don
11-26-2025 02:54 PM
When Application Builder creates an executable, it also creates two additional files; one .ini file and one .aliases file
Edit the Application.ini file to change the menu font and font size:
Original menu:
Original Application.ini file:
Added one line to the .ini file:
and the menu looks like this:
This works on LV2024 with menus created using the Edit --> Run-Time Menu... command
Alejandro A
