Run-time menu appearance change (LV8+)
Hi Craig Dobis,
The easiest way to do this is to add the following line
systemFont="1" 24
towards the end of the Application.ini file that is created along with the Application.exe file. The number 24 decides the font size. Also, you need to copy the .exe and .ini file together if you are planning on distributing the executable.The following KnowledgeBase talks about the .ini file.
Windows decides the default font size of the programs that run on it and hence changes the Executable fonts. Check this KnowledgeBase for more information on that.
Hope this helps
Message 11 of 17
(1,624 Views)
craigdobis wrote:
Is there a way in Run-Time Menus to change the font or font size of the menus? This is in LV8.5 that we are working on, W-XP.
I m afraid, there is NOT a way to do this as we wish to... Smiley Sad
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 17
(1,617 Views)
Sorry, not finished yet, due to posting problem... Smiley Mad
I think you were talking about changing the Font & Font Size of the RTM, not the font of LV on the whole, right?
If I m wrong, please correct me.
Message 13 of 17
(1,616 Views)
I also believe it is NOT POSSIBLE to can change the 'Run-Time' menu font type or size.
Message 14 of 17
(1,605 Views)
Yes, you are correct. I meant to change the RTM font and font size. However, if any of you have created your own menu bar to replace the RTM, I would be very interested in seeing that. I am sure with all the extra creative minds on this forum,  someone must have created their very own, super-fantastic menu system.
How about a "Flash" menu in an Active X container? Hhmmmmm....
I will have to think about that one.
Thanks to all of you!    MERRY  CHRISTMAS !!
Craig Dobis
Since Labview 3.0 on 3.5" floppy disks.
Still don't know all of it!
Message 15 of 17
(1,603 Views)
I think either National Instruments used to ship an example with fly-out menus before they offered the tree control, or I saw something like this in LabVIEW Technical Resource many years back.  I am sure someone still has that example somewhere.
And speaking of the tree control - maybe you can customize this and use as a menu?....Don
Message 16 of 17
(1,600 Views)
When Application Builder creates an executable, it also creates two additional files; one .ini file and one .aliases file
Edit the Application.ini file to change the menu font and font size:
Original menu:
Original Application.ini file:
Added one line to the .ini file:
and the menu looks like this:
 This works on LV2024 with menus created using the Edit --> Run-Time Menu... command
Alejandro A
Message 17 of 17
(37 Views)
