Runtime Menu of Radio Buttons
Dear All,
How to add event case to the runtime menu associated with Radio Buttons?
There's a property in Event Case for Radio Buttons but that includes the whole Rectangular Box consisting of Radio Buttons, and not individual Radio Button.
I want to add an event case for for menu selection for individual Radio Button as I am having 4 Radio Buttons, and menu associated with each radio button is different.
Ritesh
(3,654 Views)
The event structure returns a reference to sub-item. If you right-click on the boolean, caption or boolean text of one of the buttons you get a valid reference and you can figure out (with caption see example) which element is clicked, if the right click is on the border or background of the radio button a null-reference is returned.
Ton
Message Edited by TonP on 10-04-2008 02:25 PM
My LabVIEW Ideas
(3,650 Views)
Accepted by LVCoder
Hi Ritesh,
      I think TonP's solution will work for you, but if it's important to have a unique event-case for each radio-button, here's one way.  To create the button references, just right-click on a specific button and choose Create\Reference.
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,598 Views)
Yes tbd,
I wanted to have independent event case for individual radio buttons.
your solution just worked perfect .  :smileyhappy:
Ritesh
(3,569 Views)
