SIT Initialization Simulation Error 54
Hello all,
I have been going through the SIT examples, and have opened the "batch simulation.vi" example. Then, I have modified it so that it runs the sinewave.mdl from the sine wave example. This went all good and well. Then, I decided that I wanted to run the sinewave.dll on my PXI-8101. At this point, when I click run, it gives me the error:
Error 54 occurred at TCP Open Connection in NI_SIT_userAPI.lvlib: SIT Initialize Simulation.vi.
I think I might have missed a step somewhere, but I don't know. All I did was open the VI and click run.
Thanks.
(3,184 Views)
Never mind error 54. I am now getting error 56 TCP read error.
Exact same VI.
(3,175 Views)
Accepted by Bladhart
Is the PXI that you are deploying to a Real-Time PXI? It seems that you are getting this error because you are not specifying a driver VI for the model dll. You need to create and specify a driver VI when deploying to a RT target. Take a look at this link and it will help explain it in further detail.
David A.
Applications Engineer
(3,164 Views)
