SQL Error -2147217887
Hello everyone,
i have big trouble with send query to MSSQL. It´s a stored procedure. First procedure is InsertNewProduct and everything works fine, but every other next procedure has same error. I tried to solve this for last two days and I don´t find answer anywhere on forum. I know, that´s not problem with LV, but with SQl,but create query in LV is very specific, so please help me.
ALTER PROCEDURE [db_procedure].[InsertOperationStatus]
    -- Add the parameters for the stored procedure here
    @SerialNumber varchar(MAX) = NULL,
    @WorkplaceRegistrationNumber varchar(MAX) = NULL,
    @StatusId varchar(MAX) = NULL,
    @ActiveUserRightId varchar(MAX) = NULL,
    @ModifyUserId varchar(MAX) = NULL,
    @TimeStamp varchar(MAX) = NULL,
    @TimeZone varchar(MAX) = NULL,
    @ErrorCode int = NULL OUTPUT,
    @ErrorText nvarchar(250) = NULL OUTPUT
(1,588 Views)
Hi!
Just a hint:
I like this style very much, since it's clean and simple:
Note:
  • It can be dangerous to pass unknown strings directly into the query, so be sure to not send anything harmful  (https://xkcd.com/327/)
  • The elements of the cluster inside the array must match the expected output from the database, i.e. order of elements, number of elements and type (though, it will happily convert a number to string etc)
(1,558 Views)
