STANDA MOTOR AND BUILDING AN EXECUTABLE APPLICATION
But it should be a *.usm format
Julien
Message 11 of 33
(1,937 Views)
I am using Labview 8.2
Message 12 of 33
(1,935 Views)
sorry, I am not at my office today , i can't open 8.0.2 could you send in  7.1?  or just give me an image of the block diagram?
Message 13 of 33
(1,935 Views)
I am using the motor 8MR191-28
the controller 8SMC1-USBh-B1-1
no dll files
Julien
Message 14 of 33
(1,935 Views)
then development kit for labview from standa.it   for   8SMC1-USBh - Microstep Driver (USB Interface)  ?
Message 15 of 33
(1,930 Views)
Do you wanty a picture of the block diagram?
Could you tell me how to create a 7.1 version?
Julien
Message 16 of 33
(1,930 Views)
instead I downloded the development library for labview    from standa
 I ll try to compile, but I want to make sure I understand , is the directory you have to specify  contain vi like this?    Get State (uSMC)
Message 17 of 33
(1,928 Views)
I don't think so since I never got a message of error about a missing vi, those vi in uSMC are use correctly i guess?
What i observed is if i remove this config file or the link to the config file the prog doesn't work in both case (full program or executable version one)
So I suspect that something is going wrong with this file, I am not sure of course but i guess.
Regards
Julien
Message 18 of 33
(1,918 Views)
please try this
Message 19 of 33
(1,919 Views)
did yu try exemple.vi?
a config file should be specified directly in the application(vi), since I have no acces to the usb I am suggesting to verify with Standa.it  They would know for sure.
Message 20 of 33
(1,916 Views)
