STANDA MOTOR AND BUILDING AN EXECUTABLE APPLICATION
It works.
Do you find a pbs in what i did?
Julien
Message 21 of 33
(2,343 Views)
just in case    did you read the readme.txt
             These examples are written for NI LabVIEW 7.1.1 and later.
              This examples use NI VISA USB driver.
                Makes sure that you use 8SMC1-USBh controllers with
                 firmware usmc2503.usm or higher! In other case update
                it before programming (see User Manual, paragraph 5.4.5).
.usm is the firmware that should be updated in the 8SMC1-USBh controllers .....
Message 22 of 33
(2,343 Views)
µFor version 7.1.1 i know but they claim that it's compatible with higher version.
About the example, their were my strating point.
If try with example2 and 3 i have the same behavior that wioth the prog. that i send you.
About update i did in correct way and sevral times since i got this problem.
Julien
Message 23 of 33
(2,337 Views)
to answer you question about if I found the pbs in what you did
the answer is no, I cannot open it in 8.0.2
may be you can find an save as and specified the version, I don t know, never had to save in previous version, I ll check on this discussion group......
what is the pbs?
Message 24 of 33
(2,334 Views)
The problem with exe file
Julien
Message 25 of 33
(2,327 Views)
to save in previus version , just open your exemple top vi and save in previous version in the file menu.
http://forums.ni.com/ni/board/message?board.id=170&message.id=178027&query.id=57144#M178027
Message 26 of 33
(2,327 Views)
in the example2,  try before compiling try this
did you try this?
             run the example2 once by loading the profile, (usm)!!!
                 and stop it,
                 and select in the top         menu  operate->make current values default,
                 and save it
then try to compile.
Message 27 of 33
(2,312 Views)
No i got a GPIB error (error 7)
If you read french i got
"Raisons possibles :
LabVIEW:  Fichier introuvable. Le fichier a peut être été déplacé ou supprimé, ou le chemin du fichier peut avoir été formaté de manière incorrecte pour le système d'exploitation. Par exemple, utilisez \ comme séparateur de chemin sous Windows, : sous Mac OS et / sous Linux. Vérifiez que le chemin est correct dans une fenêtre de commande ou dans l'explorateur de fichiers.
NI-488:  Interface GPIB non existente."
If not it says that a file is not found maybe because it was moved, erase or that the path is not correct. For example because wrong symbol were used like \ in stead of /.
Julien
Message 28 of 33
(2,308 Views)
ok means my step.exe did not have the proper path for the  files  that try to read.
now i found the exemple2.vi on the standa.it site, I was able to find probable your problem, then no need to make step.exe(my exemple) working.
we shoud focus on compiling exemple2 in you labview version 8.0.2,
did you read my last post?  I think you should load the profile on the original vi before compiling and
make current value default before saving exemple2.vi
and then after try to compile.
let me know.
Message 29 of 33
(2,299 Views)
use the symbol browser to find the file
Message 30 of 33
(2,296 Views)
