01-08-2020 09:19 AM
How can I save one file in one folder which at the same time this folder has another folder inside
01-08-2020 10:32 AM
Your question is not very clear, can you make it more precise ?
Do you want to creat the folder ?
What kind of file are you trying to save ?
01-09-2020 02:08 AM
Yes, I want to create a folder and inside this folder another folder
01-09-2020 02:14 AM
01-09-2020 03:20 AM
Hola Felipe,
Yo he hecho lo mismo que tú solo que he puesto .txt en vez de .xls. Yo lo guardo todo en una carpeta pero ahora me gustaría que se creara otra carpeta dentro de esa según la fecha. Como lo podría hacer?
01-09-2020 03:26 AM - edited 01-09-2020 03:27 AM
Hi 99,
no need to capture a quite old thread when you already created your own one!
I have done the same thing as you only that I have put .txt instead of .xls. I keep everything in one folder but now I would like another folder created within that folder according to the date. How could I do it?
Use the CreateFolder function, as suggested before!
Use FormatIntoString (or FormatDateTimeString) to create your folder name "according to date"…
01-09-2020 03:47 AM
Hi GerdW,
I have alreday created a folder, but I want to separate all the files for days, I mean, I want to save the files every day in a different folder
01-09-2020 04:00 AM
01-09-2020 06:07 AM
Hola Felipe,
Perdona que te moleste. He intentado crearme una carpeta en el Disco Local C mediante este programa que le adjunto a continuación pero no consigo crear la carpeta.
Un saludo
01-09-2020 06:40 AM - edited 01-09-2020 06:43 AM
Hi 99,
again you hijacked that old thread instead of sticking with your own one…
Sorry to bother you. I tried to create a folder on Local Disk C through this program that I attached below but I can't create the folder.
What's wrong with your VI? Where do you fail?
Did you check your resulting path?
It's not recommended to have points in file-/foldernames.
Probably you want one more "\" in the path between the first and 2nd date string!?
Why don't you use BuildPath to build a path?
Why don't you use FormatIntoString (or FormatDateTimeString) to format your date correctly?
I recommend a format similar to YYYYMMDD to allow simple sorting of files/folders in an explorer window…
As simple like this:
