Saving fast acquired data, reading it later
I am acquiring 7 channels at 10kHz and 1 channel at 100kHz. Because of already existing postprocessing code, I will treat the acquired signals in MatLab. I am also pretty new in LV, want to learn.
So, since 7*10kHz + 1*100kHz is quite a lot of data, I have chosen to write it as TDMS files (1 for the 7 channels, 1 for the other one). I am trying to get the data once recorded... but can't, I am not able. I have gone through the LV Basics course lessons, read about TDMS format, tried with LV examples. I have also seen a code for MatLab to read tdms files, but won't make it work (I have 64bit xp).
Now I am thinking on saving one file per channel, just the data (no headers, author, fs, date, ...) so as to be easily read afterwards with MatLab, but I find myself that can't write a file and then read it even with LV's examples.
Any suggestions please?
Message 1 of 8
(3,705 Views)
Hi usuario,
  Whether are you trying to read the tdms files in matlab or are you unable to read in labview itself?
T hanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 8
(3,690 Views)
I haven't tried with MatLab yet, not until I can check the data in LV.
I attach some acquired files.
What do you think about writing one binary file per channel, just data (no headers...)? What data format should I use?
Message 3 of 8
(3,680 Views)
Hi usario,
  I can able to read your tdms files...why are you bothering about the  data format?Please refer the examples..
Thanks and regards,
srikrishnaNf
Srikrishna
Message 4 of 8
(3,675 Views)
I think I haven't explained it good enough, sorry. If I use the TDMS File Viewer block I am able to see the data. But only that way, I cannot graph it; nor be able to access it so that I can then write a separate binary file to be read from MatLab for example. Also, 'I cannot' means 'I don't know how please help'.
Examples I have tried:
Read TDMS file.vi
TDMS - Express read data (time domain).vi
Also:
Express Read Meas File block
Yet also:
many tries with open/creat file, read file, close file, ... blocks.
By the way, thank you very much for your effort and attention.
Message 5 of 8
(3,666 Views)
try with this Example VI. I could read the tdms File correctly and display the signals.
Message 6 of 8
(3,653 Views)
Accepted by topic author usuario
and in this way you have access to each signal see attached picture!
Message Edited by FHM on 06-10-2010 07:03 AM
Message 7 of 8
(3,647 Views)
thanks!! it works great!!
It happened that I just made this code, and this time works to me also (I can't tell why didn't worked before / what was I doing wrong before).
Thanks, your support has been very useful to me. Regards,
usuario
Message 8 of 8
(3,627 Views)
