Saving webcam images into database
I have managed to acquire the image from my webcam through the vision acquisition software but now i faced a problem because i want the image to be stored in the database so that it could be view from a webpage( like a video stream).
What i did in my vi was just take the image out and connected it directly to the database and data is going in the database but when i tried to display it on the webpage it does not show.
Is it possible to do that and if so is there any tutorials i can refer to?
(3,110 Views)
You should not save an image to database, since it'll make database slow, and difficult to write a web page to load image.
Save an image to specific location, and save image location to database.
Then, use <img> tag to call an image in web page.
(3,091 Views)
thanks for the reply but how do i continuously write the image to a file path from the image acquired i cant connect the image out to the write jpeg file vi directly is there a way to go about this?
(3,086 Views)
Accepted by bloodxrage
Use IMAQ Write File 2 VI
(3,083 Views)
thanks for the help i have manged to save it.
(3,076 Views)
