Scale legend of graph
I have a question about scale legend of graph.
In the scale legend (attached file), there are a axis name box and three buttons for each axis. Is there any way to show only the three buttons without the name box?
To save a space of a front panel, I would like to delete the name box. But I cannot find a way to do it from the property menu.
(3,301 Views)
Ho nobuyuki,
options:
- use the plot legend, but hide the plot labels behind a decoration
- don't use the plot legend at all, but program your own buttons to manipulate the plots…
(3,299 Views)
Accepted by nobuyuki
There is a possibility but it a little bit tricky. Try to select the Cluster inside the scale-legend array like here:
and then go to "Edit" -> "Customize Control". Now right-click the string and select "Advanced -> Hide Control".
Close the customize dialog and apply the changes to your control.
Regards, Jens
Kudos are welcome...
(3,269 Views)
Thank you so much!!!
I could achieve exactly what I wanted.
best regards,
nobuyuki
(3,253 Views)
