Scaling an Array of Numbers
Hello!
So I have a 2D array of values from 0 to 1023 that represent readings from a sensor. I need to scale these to -200 to 200. Any ideas on how to easily do this? Thanks!
Example of array:
514  578  233
513  555  122
513  789  514
Message 1 of 16
(6,697 Views)
Math.
Take array, divide by 1024, multiply by 401.  Subtract 200.
Message 2 of 16
(6,691 Views)
Accepted by ebohannon
@RavensFan wrote:
Math.
Doesn't that scale between -200 and 200.608 (1023/1024*401-200=200.608)?
AFAIC, divide by 1023, multiply by 400, subtract 200.
Or, more general subtract the min input, divide between max input - min input, multiply by output range, add output offset.
And of course if the array gets big, divide 400 by 1023 first, then multiply it by the array. That will trait two expensive array multiplications for one scalar multiplication and one array multiplication.
Message 3 of 16
(6,643 Views)
wiebe@CARYA wrote:
@RavensFan wrote:
Math.
Hard to say.   0-1023 consists of 1024 integer values.
-200 to 200 consists of  401 integer values  +/- 1-200  and zero in the middle.
The answer should get the OP close enough.  If it doesn't quite work the way they want, then perhaps they need 400 instead of 401.  Or 1023 instead of 1024.  Or perhaps both.  The two ranges aren't easily divisible with each other.  So answer may never be exact.
Message 4 of 16
(6,637 Views)
Do you know if compound arithmetic is smart enough to do this internally?
Message 5 of 16
(6,630 Views)
Not without testing.
It would be silly if it didn't, so my bet would be that it is smart enough.
Message 6 of 16
(6,624 Views)
Another option would be to use linear evaluation (offset and slope have been discussed).
Also works for 2D arrays, of course.
Message 7 of 16
(6,607 Views)
Seems that I was wrong...
Here's my test bench. And it's tricky, Sometimes any change makes the time double, and a random change makes it go back. I feel like these values are "realistic" though, after giving each option several go's. I used a median before the mean, as strong outliers added about 20% noise on the results.
The results:
Definitely some unexpected weirdness going on here!
A being (much) faster then B? Weird!
A being (much) faster then C? Weird!
B being faster then C? Weird!
E being the slowest? Sad. A factor 2.3 is quite a bit slower... This could\should be just as fast as A.
DISCLAMER: Tested in 2013... 2017SP1 is a bit faster for all cases, but the order and ratios are pretty much the same.
EDIT: It get worse:
5.5 times slower then the fastest way... Smiley Sad
And, just for the record:
Message 8 of 16
(6,574 Views)
They are within the noise.  I would expect them to actually compile to the same thing due to optimizations that the compiler does such as moving that first multiply outside of the loop.
Message 9 of 16
(6,564 Views)
That it's slower when you wire the scalars on top isn't that surprising. There's some threads on LV memory management, and if you wire an array on top it usually work in place, while a scalar on top forces it to create a new array.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 16
(6,558 Views)
