Scan From String Madness
This:
s1.png Yields 3 strings: "ABC", "DEF", "GHI".
Whereas this:
s2.png  Yields 3 strings: "ABC", "GHI", "", and an error.  WHY?  (Oh I know there's a reason, just not a good one).
Of course there are lots of ways to parse out the string so the double new-line would yield a null string in the middle, but is there a trick to get Scan From String to do it nicely?
(4,354 Views)
I'm guessing it has to do with how LabVIEW treats "whitespace". Looking into the "trim whitespace.vi" it uses regex to look for tabs, space, carriage return and newlines AND any number of them. Two newlines are probably treated as a single entry of "whitespace".
You've probably figured a way around, but here's one that specifically looks for each newline character and splits the string by that.
(4,320 Views)
@paul_cardinale wrote:
This:
Whereas this:
I think this might have actually worked in LV 2012.
Bill
CLD
(Mid-Level minion.)
(4,280 Views)
This works, it's just a lot messier than Scan From String would be:
(4,261 Views)
Accepted by paul_cardinale
A regex with submatches also works:
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(4,217 Views)
(4,199 Views)
Doesn't handle blank lines.
(4,166 Views)
